18-08-2023 10:04 PM
Hi
I have an S21 Ultra 5G but I never get anything like 5G speeds. I just did a speed test and after the page finally loaded my speed was 240Kbps..
So what do I need to get 5G speeds?
My contract is 5G..
T
06-10-2023 12:40 PM
Hi @Dragon_
You can check if the device is locked and request the unlock code here - Device unlock (ee.co.uk)
Hope this helps ![]()
19-08-2023 09:32 AM - edited 19-08-2023 09:32 AM
19-08-2023 09:15 PM
Does your phone display a VoLTE signal when these speeds are evident?
A 5G coverage indicator is not direct evidence of 5G service, but 4G should comfortably beat those speeds in most circumstances.
20-08-2023 12:27 AM
Hi James
I just checked and it is shows as this:
I use wifi calling when indoors and never really tried just using the phone connectivity outdoors.. So the speed I posted above (240Kbps..) is what? 3G? I've been trying to donload maps in an android unit in my car using my phone as a hotspot.. its so bloody painful.. And I have the S22 Ultra not the S21 as I put up there..
Tracy
20-08-2023 12:38 AM - edited 20-08-2023 12:39 AM
Hi Bristolian
I just tried it now and is showing as 4G.. and thats when I tried a speed check.. I have always known upload speeds to be way slower than download speeds.. so I dont know what is happening here,
20-08-2023 11:01 AM - edited 20-08-2023 11:01 AM
What does the predicted 4G coverage look like on the coverage checker @Dragon_ ?
20-08-2023 06:18 PM
Afternoon James.
This is the 4G coverage..
If this is what you meant?
Tracy
21-08-2023 08:08 AM
Thanks @Dragon_
Does the Network Status Checker show any reported problems for the area if you select the 'check status' option after entering your postcode and device?
21-08-2023 05:53 PM
Hi Lianne_T
There are no issues
22-08-2023 08:00 AM
Thanks @Dragon_
If you report the problems you are having our network team will get this looked into and keep you updated.
Leanne 🙂
