Upgrading contract woes.
apb123
I have 5 mobiles for the family through EE. Unlimited data and calls. It was under the rolling contract EE One NF SIM UL. We had no problems.
I have upgraded the contract because we were out of contract under the same unlimted data/cals and we have all had problems with being unable to makes calls and data caps.
Looking at the contract under EE it seems the new contract is for SIM 10GB 24M.
I phoned and didn't really get anywhere. Should I just cancel it and go back to our rolling contract (it is within the 14 day period) or shall I try customer services again?
Northerner
Hi @apb123
Just changing your tariff shouldn't impact anything on your account unless you have downgrade but it seems from your post you're no longer on unlimited if you're on the 10 GB plan. As you suggest yes you need to speak to EE CS on 150.
Northerner
Hi @apb123
What were those problems?
