on 22-03-2026 11:35 AM
Galaxy S23 - I bought a replacement handset and having put in my existing sim card, it attached to EE network but only offers 2g as the data provider, I no longer get 4g/5g data.
swapped sim card back in to older handset and all works fine.
tried suggested:
recycle Flight mode
re-seated sim card
reset network settings
turned of and on again etc
latest updates applied
No network coverage issues - all other EE devices can get at least 4g network?
on 22-03-2026 11:59 AM
Hi @PGellatly
Where did you get the handset.
What firmware *#1234#
Check device network mode settings: Settings > Connections > Mobile networks > Network mode SIM1 or SIM2 > Select network mode > set device network mode as 5G/LTE/3G/2G (auto connect) mode.
Check network operator settings: Settings > Connections > Mobile networks > Select automatically > OK > Registered on network
on 22-03-2026 12:39 PM
Do you get 4G/5G for voice or background usage?
Where did you buy the replacement handset from?
