06-06-2026 03:27 PM - edited 06-06-2026 03:30 PM
It is now pretty much confirmed that the recent (circa 25/5/26) firmware update on EE Smart Hub Plus (with Wifi 6) to version r4.26.1-R-1860948-PROD-83002 is causing a lot of problems around wi-fi dropouts, probably all on the 2.4 GHz frequency (and probably on both Main and Compatibility). The update was something to do with aligning BT and EE routers, no other details given.
Many people are suddenly getting random dropouts which were not there before, which temporarily stop after a reboot, particularly by powering down for at least 5 minutes. I personally also found our phones could not even see both Main and Comp networks when the problem was occurring. Almost universally, the fix is to go into the router Wi-Fi configuration page (Change Settings) and change the 2.4 GHz channel config from Auto to Fixed (many are using channel 6).
I have also seen a laptop reconnect every 6 seconds (to the 2.4 GHz Comp network) where I have tried all the usual - update Wifi adapter driver version, back off certain adapter sensitivity settings - and I even bought a new USB Wifi Dongle, which also would not connect stably. This laptop was absolutely fine before the update (as were the phones that were dropping off the wifi). We're now using that laptop on Ethernet-over-mains, somewhat less convenient but totally solid (and Amazon have refunded the Wifi Dongle 🙂 )
Today I had an excellent conversation with one of the EE Guides (using their callback system which imho is a pretty good way of getting hold of them) and he agreed I'd already done pretty much everything I or EE could do, and will escalate this.
He indicated that any sort of routine firmware update is unlikely very soon, but that they are aware of these wifi problems, and implied (or maybe I read into it) that an update can sometimes be rolled out to fix specific problems.
So I think the best thing to move this forward positively is for everyone to report the problem to EE. Text GUIDE to 66033 and they will call you back in usually less than an hour. The more who report, the stronger the case.
Before doing this it may speed things up if you do a Factory Reset on your router (under Advanced Settings / System) and then reconfigure it the way you had it before (e.g. turn Comp on, etc.) then check the issue is still there. We pretty much know this reset does not work, but the support team do have a sequence they need to go through and a Factory Reset is one of those steps, so doing this before will speed things up.
Thanks everyone - fingers crossed.
25-07-2026 11:27 AM - edited 25-07-2026 11:52 AM
@Pervs2 Did you say that the Ring Doorbell is connecting to the EE Hub direct or is a Netgear where it's latching on too, just checking those out now? The spec's look real good on them and have the ability to go WPA3 so chipset must be up there, see there is also some lights on them for checking, also would look at them with the Netgear app to see if WPA2-PSK which is the same as WPA2-Personal if given a choice.
Honestly you just do not know what EE has done with all the latest FW update, and yes i do appreciate it was all tickety boo before and now pear shaped.
Not using a landline then this is what i would be looking at to complete what you have.
on 25-07-2026 11:50 AM
The ring doorbell has only ever been set up to connect directly to the main network on the hub as it is right next to it. The NetGear’s are only used for 2 cameras at the back and I have no issues with these ones generally.
as mentioned when my phone can’t connect to the main WiFi it sometimes connects to my extenders which work fine. And the bizarre thing is these use the hub to boost signals!
I think the issue is with devices connected to the hub and around security issues hence the password is incorrect problem.
on 25-07-2026 12:47 PM
The extender is In the room above the kitchen and hub in room next to it . It’s literally happened overnight . I’ll do that text thing you said and take it from there I’ll do on Monday when they’re at full capacity staff wife
on 25-07-2026 12:54 PM
@MartCAFC No need to wait 7 day's working and automated system you just need to be at home when they call you back.
