To everyone having Wi-Fi dropouts & other problems - please **report**
Cliff_G
Skilled Contributor
Skilled Contributor
It is now pretty much confirmed that the recent (circa 25/5/26) firmware update on EE Smart Hub Plus (with Wifi 6) to version r4.26.1-R-1860948-PROD-83002 is causing a lot of problems around wi-fi dropouts, probably all on the 2.4 GHz frequency (and probably on both Main and Compatibility). The update was something to do with aligning BT and EE routers, no other details given.
Many people are suddenly getting random dropouts which were not there before, which temporarily stop after a reboot, particularly by powering down for at least 5 minutes.  I personally also found our phones could not even see both Main and Comp networks when the problem was occurring.  Almost universally, the fix is to go into the router Wi-Fi configuration page (Change Settings) and change the 2.4 GHz channel config from Auto to Fixed (many are using channel 6).
I have also seen a laptop reconnect every 6 seconds (to the 2.4 GHz Comp network) where I have tried all the usual - update Wifi adapter driver version, back off certain adapter sensitivity settings - and I even bought a new USB Wifi Dongle, which also would not connect stably. This laptop was absolutely fine before the update (as were the phones that were dropping off the wifi). We're now using that laptop on Ethernet-over-mains, somewhat less convenient but totally solid (and Amazon have refunded the Wifi Dongle 🙂  )
Today I had an excellent conversation with one of the EE Guides (using their callback system which imho is a pretty good way of getting hold of them) and he agreed I'd already done pretty much everything I or EE could do, and will escalate this.
He indicated that any sort of routine firmware update is unlikely very soon, but that they are aware of these wifi problems, and implied (or maybe I read into it) that an update can sometimes be rolled out to fix specific problems.
So I think the best thing to move this forward positively is for everyone to report the problem to EE. Text GUIDE to 66033 and they will call you back in usually less than an hour.  The more who report, the stronger the case.
Before doing this it may speed things up if you do a Factory Reset on your router (under Advanced Settings / System) and then reconfigure it the way you had it before (e.g. turn Comp on, etc.) then check the issue is still there.  We pretty much know this reset does not work, but the support team do have a sequence they need to go through and a Factory Reset is one of those steps, so doing this before will speed things up.
Thanks everyone - fingers crossed.
8 REPLIES 8
Community Hero
Community Hero
@Cliff_G I am fully ANTI the Full Factory reset, have NEVER found that it resolves a single issue and NOT saying that it does or does not, The EE script will be that way, had it with Sky years ago and correct until it's done the Agent does not give a F F in the slightest.... Guess what the sky one did Hee Haw but the Impass could not be surmounted until it was done..... At least they had a backup/restore that EE does not....
Line fault was the issue, but what do i know, you know what i mean....
As a little footnote, took me a good 5/6 hours to set the EE Smart Hub + up between the web Manager and stupid App to HOW i needed it to be, takes EE an overnight FW update to mess things up, badly in my case, but i knew what they did so worked around the needed to get working again, If backup/restore had been an option 5 minutes fix so makes a huge difference in time!
boxer121
The update has screwed everything up in my home, Ring doorbell system and security cameras drop way too much. Surely this is a breach of contract ?
@boxer121 If you are assuming that the FW update is the cause off your issue, then apply the Fixed channel and see how it goes, do you need the link for the step by step guide, from @bobpullen that he stuck to another post?
(2) Solved: Re: my outside camera keeps going offline. - The EE Community
Give it a try if it works, will take a couple days for you to see back to normality, then post back with success or failure... Sugar happens.
UncleG
I spent 4 days trying to work out what the F was going on not knowing there had been a change on my hub and the first 2 days of talking to EE this was never even suggested as a reason for my problems. It is only this morning that I have been told that and now have my laptops back connected via a Comp but still having problems with other hardware not connecting. Not a happy bunny.
Community Hero
Community Hero
@UncleG Are you talking about the EE Smart Hub 6 Plus version? That's the puppy that had all the problems EE will admit to currently?
No Smart Hub SH31B
@UncleG : That is the SH 6 +, FTTC/FTTP model.
Community Hero
Community Hero
@UncleG Devices not connecting can be for a few reason's, instability can also be for others, since you now have the EE Smart Hub 6 Plus version, the SH31B as you say, best check first you are at the latest FW version with less stability issues, copy off where it was going to and from below versions wise last 3 only....
FW: r3.8.30-R-1627300-PROD-83002 and the gui is at App version 3.1.18 05/12/2025
FW: r4.26.1-R-1860948-PROD-83002 and the gui is at App version 3.14.5 25/05/2026 OP Posted Stability Problem
FW: r4.26.3-R-1923144-PROD-83002 and the gui is at App version 3.14.5 12/06/2026 OP Posted
Linked what EE has now listed in the pinned posting also as it has recently been updated.
EE Hub firmware versions - The EE Community
