EE Hub firmware versions
James_B
EE Community Manager
We regularly update your Smart Hub to keep your broadband secure, stable, and performing at its best, often adding new features and behind-the-scenes fixes.
Hub name Model Current firmware version Notes
Smart Hub 6 Plus SH30A r4.26.3
Smart Hub 6 Plus SH31B/SH32B r4.26.3
Smart Hub 7 Plus SH35A r5.21.1
Smart Hub Pro SH40J r5.16.1
⚠️ It can take several weeks for everybody's hub to be upgraded to a new firmware when it becomes available. The table above reflects the most recent software version that has been rolled out to everybody. This means that your hub may be running a more recent version (higher number) but should never be running an older version (lower number).
If you’ve just set up a new hub, leave it switched on and connected to the internet for 24 hours. This gives it time to download and install the latest update.
How can I check my hub’s firmware version?
Web browser
  • Open the Hub Manager in a web browser by going to the address http://192.168.1.254
  • When you visit 192.168.1.254 to access your EE Hub Manager, your web browser might display a message saying your connection isn’t private or secure. This can seem worrying—but it’s completely normal and safe in this case. Security warning when accessing the Hub Manager
  • Go to 'Status' and enter Hub admin password when prompted
  • Firmware version is listed there. Note it will be in a longer format e.g. r5.3.0-R-1805084-PROD-1 = r5.3.0
EE App
  • Open EE App
  • Navigate to Manage > Broadband
  • Pair your hub to the App if you haven't already
  • Tap Settings icon under the image of your hub
  • Tap Hub Details
  • Scroll to bottom
List of the recent firmware versions and release notes so you can see how we’ve improved your broadband experience behind the scenes
Firmware version: r5.16.3
Deployment date: From October 2026
Hub Types: SH40J
Release notes:
  •  Fix - WPS-paired WiFi devices dropping connection after hub reload/restart
Firmware version: r5.21.1
Deployment date: From September 2026
Hub Types: SH35A
Release notes:
  •  Fix - WiFi stops working after firmware upgrade if 2.4 and/or 5GHz SSIDs have been disabled
Firmware version: r5.19.1
Hub Types: SH30A, SH31B, SH32B
Release notes:
  •  Fix - First time firmware upgrade can result in loss of WiFi/certain features
Firmware version: r5.18.1
Deployment date: From August 2026
Hub Types: SH35A
Release notes:
  •  Platform updates & security patches
  • Improved WiFi and extender stability/performance
  • New - New Hub Manager UI (Beta)
  • New - Expanded event logging
  • Fix - Issue affecting certain traffic/activities e.g. PS5 downloads/IPv6 applications
  • Fix - Custom DNS feature issues hub IP as secondary server
  • Fix - Pixelation/IPC6023 errors in some situations when viewing subscription EETV channels
Firmware version: r5.16.1
Hub Types: SH30A, SH31B, SH32B, SH40J
Release notes:
  •  Security patches
  •  New - Updated WiFi controller with improved logic/decisioning (SH31B/SH32B)
  •  New - Removed support for 2.4GHz extender backhaul (SH31B/SH32B)
  •  Fix - Some extenders dropping connection after firmware upgrade
  •  Fix - Temporary Loss of 5GHz extender backhaul in certain conditions (SH3x)
Firmware version: r4.29.1
Deployment date: From June 2026
Hub Type: SH40J
Release notes:
  • Fix - Connectivity Backup not working over WiFi
  • Fix - 5GHz WiFi sometimes stops working after firmware update
Firmware version: r4.26.3
Hub Type: SH30A, SH31B, SH32B
Release notes:
  • Fix - Intermittent 2.4GHz connectivity
Firmware version: r4.28.1
Deployment date: From May 2026
Hub Type: SH40J
Release notes:
  • Improved WiFi stability/performance
  • New - Digital Voice Contacts backup/export
  • New - IPv6 DNS
  • New - EE WiFi-Auto
  • Fix - Microsoft Teams/UDP issues in some situations
  • Fix - Ethernet/wired devices taking a long time to establish connection
  • Fix - Manual 2.4GHz channel selection not working
Firmware version: r4.27.1
Hub Type: SH35A
Release notes:
  • New - IPv6 DNS
  • New - EE WiFi
Firmware version: r4.26.1
Deployment date: From April 2026
Release notes:
  • New - IPv6 DNS
Firmware version: r3.35.24
Deployment date: From January 2026
Hub Type: SH35A
Release notes:
  • Improved EETV stability/performance
  • Improved Digital Voice performance
  • Fix - Unable to assign static DHCP IP To LAN device
  • Fix - Port forwarding rules not working in some situations
  • Fix - WiFi Optimiser sometimes stops boosting
  • Fix - IPC6023 errors in some situations when connected to 2.5GbE ONT
Firmware version: r3.8.30
Deployment date: From November 2025
Release notes:
  • Improved Digital Voice reporting
Firmware version: r3.8.24/r3.8.26
Deployment date: From September 2025
Hub Type: SH30A, SH31B, SH32B, SH40J
Release notes:
  • Security patches
  • New - WiFi Optimiser Stream Mode
  • New - EE WiFi
  • New - Retain Extender/Hybrid Connect pairing after Hub reset
  • New - Custom DNS for SH40J
  • New - Force HTTPS for Hub Manager
  • Fix - UPnP not working
  • Fix - Errors when attempting WiFi Optimiser setup
  • Fix - WPS sometimes failing when trying to pair EETV box
  • Fix - Calling/registration problem affecting some 3rd party VoIP services
  • Fix - Intermittent hub restarts
0 REPLIES 0
