EE SOTAP Broadband Issue Following BT→EE Migration. Router the issue
Terry9999
I was recently migrated from BT Broadband to EE onto a new SOTAP/SOA DSL service there is no fibre available.
New line service and router is 2 days old now. My router is an EE Smart Hub 6 running firmware R4.26.3-R-1923144-PROD-83002.
Since the migration, general internet access works normally, but several specific services do not. They worked with no change prior to new service router.
2 issues
  1. My LG TV cannot use streaming services fails to connect, despite internet connectivity e.g. Netflix and LGTV app/content store. Streaming works on an AppleTV using same ethernet cable
  2. I cannot RDP sessions to AWS-hosted servers.
Netflix diagnostics on the TV App can connect to Netflix servers 1-3.
The RDP tab/window but then fails with: "Unable to connect to xx.xx.x.x:3390. The two computers couldn't connect in the amount of time allotted." If I run connection TCP test to xx.xx.x.x:3390 it connects
Works on another connection
However, if I disconnect from EE broadband and connect the same laptop to my mobile phone hotspot, the same AWS server connection works successfully.
The only thing that changes is the internet connection being used.
Troubleshooting performed (had support call with EE):
  • Rebooted and reset the EE router multiple times confirmed picking up correct IP details
  • Changed DNS to Google DNS (8.8.8.8) on TV and router
  • Confirmed the laptop is using Google DNS tested reverted back to Router
  • Tested the LG TV/laptop using both Ethernet and Wi‑Fi.
Immediately after migration, the BBC iPlayer failed on the LG TV. BBC iPlayer later started working by itself.
The common factor appears to be the EE broadband connection/Router .
The Fix
Today I plugged my old BT SMART HUB 2 router in. The TV and my RDP connections worked.
I know my new EE Smart Hub 6  could be a faulty router but I would expect more things to be broken just not just Some internet services on some Devices. Concerned there might be some config differences between Hubs 2&6 not visible on how it handles data
Has anyone else experienced similar issues following migration to EE SOTAP broadband where general internet access works but certain cloud services and applications consistently fail?
8 REPLIES 8
Maestro
Maestro
@Terry9999 The from and too below.
FW: r4.26.3-R-1923144-PROD-83002 and the gui is at App version 3.14.5 12/06/2026 OP Posted
FW: r5.19.1-R-2036010-PROD-83002 and the gui is at App version 3.17.5 17/09/2026
So the firmware needs updating? can't see anywhere in config portal that allows me to invoke an update I would have thought this would be done remotely by EE?
@Terry9999 Here is the pinned linked post, copied it for you. If you wish to stay with the 6+ hub then good luck, you will need it.
EE Hub firmware versions - The EE Community
Thanks, appreciate your replies.  I have a Smart Hub 6 Plus
doesn't sound good is it that bad. What are my options, remember I'm on ADSL.  I've an old BT smart hub 2 and a personal router but would like to get it working with EE's router and their config so I can get support. Then once stable I can change router.
The issue is the RDP stuff is v.important for me I need it working.
Before I contact support again what's the best way to proceed. I spent ages diagnosing this I don't want to go through all of the steps Support will get me to do, often many of them aren't logical
@Terry9999 Bad is yes, keep the BT Smart Hub2 on the connection, that is fully supported on the EE/BT connection.
EE's only option modem wise for a WiFi6 connection is the EE SH31B version that you will have, it's the only one with a VDSL/ADSL modem stage on it. the 2023 model is a stripped down SH2 with inferior modem stage (SH20A).
BT Broadband
Above if you wish to use the BT tool, and show your connection, use the address checker best option and hide any personal details as it will not get approved if you post.
Thanks @JimM11
I've checked that bt broadband page before only shows ADSL available, page not working for me now. I'm familiar with my Cabinet had an Excellent open reach  engineer out. He confirmed my cabinet and it's missing fibre to premises  and also fibre to cabinet. The cabinet is a stones throw from exchange.
Of subject a bit but I'll keep my old bt hub 2 plugged in for a while so when Big brother  (EE) checks I'm still ok. I'll then swap out for another old router I have which allows me to switch on Quality of Service QoS (I think its called) to stop buffering on the router from flooding the adsl esp upload line - suggested improvements I've found on line and I want to try but need router than allows me to set this.
@Terry9999 No problem, with an old ADSL line you will not have any good speeds down/up the line anyway, and if your cab is not VDSL equipped may just be a waiting game for you.
Edit:- did a quick check and the BTW is working fine for me just now on the address checker.
Port 3389 still seems to be the official RDP port microsoft based. May be worth checking and doing a direct PF rule to get through the NAT, or others are disabling IPV6 currently but that i do not agree with for a Router.
Thanks @JimM11  glad I posted I would have still have been wasting my time.
I went back to using BT home hub 4 (sorry said it was 2) and now using my own router and weird streaming and RDP issue solved.
