WiFi connection
Nicole922
We are having problems with our WiFi, seems to go in and out of connection. Have looked into it all via the app. Says no problems. Can you help?
Maestro
Maestro
@Nicole922 The Forum is not EE CS, you can send a text HELP to 66033 if your mobile allows that and have EE check out your system,
Maestro
Maestro
BB issues are rarely widespread but specific to your own line.
If it is a neighbourhood issue, you could consult Check service in your area  to see if any faults are being attended to in your local area. You may also Report a Problem there.
Have you reported your problem with your BB to EE? They can't do anything about it until you do. Text HELP to 66033 to get EE to test the line & see what needs doing.
Which EE router & WiFi extenders, if any, do you have (read label or post a pix)? What is the name of the EE BB plan are you on including its speed?
