Smart Hub 7 Plus does not retain wifi settings
DigiVIV
The Smart Hub 7 Plus is annoying in various ways, but the most annoying seems to be that it doesn't do what I tell it!
I have turned off the 2.4Ghz band for the "Main" wifi and also turned off the 5Ghz band for the "Compatible" wifi (so that there are separate SSIDs for the 2.4 and 5 GHz bands).
But whenever the hub restarts it reactivates 2.4Ghz for the "Main" wifi.
It keeps the 5Ghz off for the "Compatible" wifi, so clearly is half listening to me!
Am I missing something, or is this just a bug that needs fixing? (And if the latter, could EE fix it please, pronto?!...)
19 REPLIES 19
Maestro
Maestro
@DigiVIV Why are you trying to do that to the main wifi, the mlo needs them both on for the operation, the unit is NOT separate SSID capable so that may just be the reason it turns it's self back on, what channels are the 2.4Ghz bands using if you know or can check. The unit also has hidden ssid and ee wifi operating in the same band ranges also.
DigiVIV
Well, you've hit upon another annoyance there, because it's not possible choose channels!  🤷‍♂️
But either way, the reason why I want a setting isn't at issue: only that the setting, although available, doesn't set!!  🤦‍♂️
(Which is worse than it not being an option.)
@DigiVIV - odd behaviour indeed and sounds like a bug. Is it critical that the devices connected to the main SSID do not use 2.4GHz?
It should be possible to fix the 2.4GHz channel. What problems are you having in that regard?
@bobpullen If you get a chance take a look at the link from posting, Re: Wifi issues - Page 3 - The EE Community
Did not get the full picture off all the channels and associated macs, did ask and a lot going on with the Plus/Smart wireless ssid/channels.
@JimM11 - just taken a look but can't see the relevance. The signal strengths etc. look fine in that thread.
For @DigiVIV's problem, it should be pretty easy to replicate. I'll just need to find a gap where I'm not going to annoy the rest of my household with my fiddling 😂
Hi @bobpullen ! Thanks for taking an interest. I mean, it's home broadband, so even with WFH I'd hesitate to describe it as critical  😉   I  have a Ubiquiti  AP I can use to work around the problem if necessary, I suppose. But yes, the main reason for wanting the control is an older Mac. And one way or another I need to achieve my aim of keeping it on 5Ghz. There's no way to force it to connect to 5Ghz without a separate SSID. It tends to slip back to 2.4Ghz having initially connected at 5Ghz otherwise, despite getting a perfectly good signal. It was a particular problem with the PlusNet Hub 2 (have recently transferred to EE). I suspect in that case that the hub itself was especially sensitive to signal thresholds and booted devices off the 5Ghz band too readily.
You are right that the 2.4Ghz channel can be fixed on the Smart Hub 7 Plus, but it seems weird that that's the only one that can be, and it doesn't really help me!
Hopefully you can replicate the issue when convenient. I don't really have any other problems except that the OFF setting  doesn't stick on restart. Everything works fine until restart...
@DigiVIV - not being able to fix a 5GHz channel kind of makes sense. The newer EE hubs use higher power DFS channels in the 5GHz spectrum and they are regulated. What this means is that your router will be forced away from the higher channels if it detects something like weather or air/radar traffic in the vicinity. You have no control over this so the concept of fixing a channel that your router might decide not to use regardless could well lead to confusion.
The Mac will almost certainly be making decisions itself as I'm fairly confident that the Plusnet hub doesn't do any proactive 'steering' itself.
I'll do my best to see if I can replicate things when I next get the chance. If it is a bug then the more noise the better 😉
@bobpullen Yes, clearly what I mean is: this bug is a threat to national infrastructure and a potential risk to life. It must be rectified as a matter of urgency, otherwise EE could be liable. Seriously, though, it is a real problem because the hub can end up being turned off / restarted in an unplanned way for a number of reasons, including power cut, (it has been when the firmware was updated and the backup battery installed: hence discovery of bug) and if I'm not here to fix it, or don't realise or forget, then the setup I have chosen to put in place for good reasons stops working correctly. You have to be able to rely on available configurations being maintained.
What you're saying about DFS makes perfect sense; but in the same spirit of certainty and reliability, given my particular location and purposes, I would opt not to use those channels if the Smart Hub 7 Plus offered the choice. (Maybe it does in the "Compatible" wifi, but then I wouldn't get the two separate SSIDs.)
Anyway, I'm pretty sure this is a bug and would be most grateful for anything you can do to get it squashed in a firmware update  🙂🙏
I have to use the EE hub because of Digital Voice, but other minor annoyances I've been able to work around (eg. there's something going on with the DHCP and/or DNS services that that Mac also doesn't like so it loses internet connectivity occasionally unless TCP/IP is configured manually, Android devices tend to disconnect unless Transition mode is used for authentication, a Roku box on the 2.4Ghz network isn't happy unless IPv6 is off...) and everything is basically hunky dory... provided the router isn't restarted!  💣
I must say, the obligatory DFS and "smart" channel selection are proving to be very irritating, so if there is any possibility of controls being provided to disable those features in a future update, that would also be most welcome. All they deliver for us is regular periods of lost connectivity. I may have to switch off the EE wifi altogether and use Ubiquiti instead.
The extra SSIDs that @JimM11 flagged are equally unwelcome. I also get the point about MLO; but do not need to use it.
All in all, the Smart Hub 7 Plus is perhaps trying to be a bit too "smart" -- and making a pain of itself in the process!
