12-10-2026 04:47 PM
Rebooted Router and ONT and issue still continues. No problems up until today, EE txt Help advises no issues!
Router time is out by 2 hours as well which is weird!
Product code: SH4-1
Connection type: External (FTTX)
App version: 3.17.5
Firmware version: r5.16.1-R-2011329-PROD-1
WAN link speed: 2.5 Gbps
Network uptime: 1 Hr 0 Mins
System uptime: 1 Hr 1 Min
| 10/12/2026, 01:41:52 PM | Internet status is offline |
| 10/12/2026, 01:43:52 PM | Internet status is online |
| 10/12/2026, 01:44:52 PM | Internet status is offline |
| 10/12/2026, 01:45:52 PM | Internet status is online |
| 10/12/2026, 01:46:52 PM | Internet status is offline |
| 10/12/2026, 01:52:52 PM | Internet status is online |
| 10/12/2026, 01:53:22 PM | Internet status is offline |
| 10/12/2026, 01:56:22 PM | Internet status is online |
| 10/12/2026, 01:56:52 PM | Internet status is offline |
| 10/12/2026, 02:01:22 PM | Internet status is online |
| 10/12/2026, 02:02:22 PM | Internet status is offline |
| 10/12/2026, 02:02:52 PM | Internet status is online |
| 10/12/2026, 02:03:22 PM | Internet status is offline |
| 10/12/2026, 02:03:52 PM | Internet status is online |
| 10/12/2026, 02:04:22 PM | Internet status is offline |
| 10/12/2026, 02:07:22 PM | Internet status is online |
| 10/12/2026, 02:07:52 PM | Internet status is offline |
| 10/12/2026, 02:08:52 PM | Internet status is online |
| 10/12/2026, 02:09:22 PM | Internet status is offline |
| 10/12/2026, 02:09:52 PM | Internet status is online |
| 10/12/2026, 02:10:22 PM | Internet status is offline |
| 10/12/2026, 02:10:52 PM | Internet status is online |
| 10/12/2026, 02:11:22 PM | Internet status is offline |
| 10/12/2026, 02:11:52 PM | Internet status is online |
| 10/12/2026, 02:12:22 PM | Internet status is offline |
| 10/12/2026, 02:13:22 PM | Internet status is online |
| 10/12/2026, 02:13:52 PM | Internet status is offline |
| 10/12/2026, 02:14:22 PM | Internet status is online |
| 10/12/2026, 02:15:22 PM | Internet status is offline |
| 10/12/2026, 02:15:52 PM | Internet status is online |
| 10/12/2026, 02:17:22 PM | Internet status is offline |
| 10/12/2026, 02:17:52 PM | Internet status is online |
| 10/12/2026, 02:19:22 PM | Internet status is offline |
| 10/12/2026, 02:19:52 PM | Internet status is online |
| 10/12/2026, 02:21:22 PM | Internet status is offline |
| 10/12/2026, 02:21:52 PM | Internet status is online |
| 10/12/2026, 02:23:52 PM | Internet status is offline |
| 10/12/2026, 02:24:22 PM | Internet status is online |
| 10/12/2026, 02:25:52 PM | Internet status is offline |
| 10/12/2026, 02:27:22 PM | Internet status is online |
| 10/12/2026, 02:28:22 PM | Internet status is offline |
| 10/12/2026, 02:28:52 PM | Internet status is online |
| 10/12/2026, 02:30:22 PM | Internet status is offline |
| 10/12/2026, 02:31:52 PM | Internet status is online |
| 10/12/2026, 02:32:22 PM | Internet status is offline |
| 10/12/2026, 02:33:22 PM | Internet status is online |
| 10/12/2026, 02:34:22 PM | Internet status is offline |
| 10/12/2026, 02:34:52 PM | Internet status is online |
12-10-2026 04:55 PM - edited 12-10-2026 04:58 PM
@mikefairgrieve Did the EE Hub not NTP time sync at reboot, and yes you look to have the latest FW. Is the connection working and just the weird logging going on, app was updated few day's ago so worth a check at that also. Time clock sync would be needed or the schedular for parental controls would be way out....
FW: r5.16.1-R-2011329-PROD-1 and the gui is at App Version 3.17.5 20/08/2026
12-10-2026 04:58 PM
Rebooted again and still no NTP sync , still showing 2 hours out. Internet seems ok, no drop outs from any devices just lots of these reports in the logs, Tried the broadband connection test on the app and it says my router is offline.
12-10-2026 05:01 PM - edited 12-10-2026 05:10 PM
@mikefairgrieve Try the hub off for 5 mins, then see what it is like time wise when reconnected, time gives the hub power down enough for no retention settings, not sure if the log jumps back to 1970 at the start, will take a look at an old log file.
Nothing is reported that i see in the old log files for a starting time stamp.
12-10-2026 06:14 PM - edited 12-10-2026 06:15 PM
Those times look too methodical to be a fault on the line. Router seems faulty perhaps triggered by lack of time sync ( or tine sync +/- 2hrs). Request replacement by calling CS.
