15-06-2026 11:18 AM - edited 19-06-2026 10:06 AM
Following a recent firmware update, some Smart Hub Plus customers may find that certain WiFi devices or WiFi extenders have trouble connecting.
Our engineers have identified the cause of the problem and are now rolling out a fix to affected Smart Hubs.
If your wireless devices aren't connecting and you have a Smart Hub Plus, setting the 2.4 GHz channel can resolve the issue.
If you have devices that will not connect, please try reconnecting using Compatible WiFi.
We are working as fast as possible to fix this issue, but in the meantime, some of our customers have found the following steps help:
You can find all the latest updates on this issue in Fix problems connecting devices to your Smart Hub Plus or Smart Hub 3's WiFi | Broadband Help | EE
on 19-06-2026 03:48 PM
@James_B we're now up to r4.26.3 as of some time yesterday. I've switched back to Auto channel on the 2.4 GHz and will monitor.
Unfortunately this FW update has not fixed the problem we have on one laptop, which is re-connecting every 6 seconds. Normal browsing and email is just about ok, but streaming or a Zoom call are unusable. We did not have this before the update to 4.26.1 so there's still something not fixed in 4.26.3. I'll raise a new topic to try and gather anyone else seeing this.
I did consult with a Guide and we eliminated everything possible, but 4.26.3 has also not helped. Their final advice was to recheck with HP but they have been unable to help.
19-06-2026 03:58 PM - edited 19-06-2026 04:05 PM
@Cliff_G As posted and pinned now by @James_B will link the main one below but the extract with the Fix teams/UDP is were i would be suspecting you 6 second issue is happening, DO NOT be listening much to the Guide advice, not happening before will be NOTHING to do with HP, at least your Ethernet keeps it going, so did the guide not pick that up WiFi issue?
Firmware version: r4.26.1
Deployment date: From April 2026
Hub Type: SH30A, SH31B, SH32B
Release notes:
EE Hub firmware versions - The EE Community
@Cliff_G Pretty sure i remember you saying connected wired may have been a bit of powerline etc but let you find that and compile it as needed, @James_B has been tagged so have EE reach out they should be able to see that online with the Homeview+ software they use.
on 19-06-2026 04:12 PM
"Fix - Teams/UDP" is where I would be suspecting your 6 second issue is happening.
Agree. But I probably need more than one person to be having this to get anywhere.
on 19-06-2026 04:18 PM
@Cliff_G Is it a windows laptop, if so have a look on the computer management, event viewer, windows logs to see if anything network orientated going on writing in the log file/s.
on 22-06-2026 04:10 PM
Firmware r4.26.3-R-1923144-PROD-83002 has fixed it for me too.
on 04-07-2026 10:04 PM
I am having the issue with 2.4ghz devices disconnecting on my Home Hub 6+ SH31B, f/w r4.26.3-R-1923144-PROD-83002. It started at the end of May and is going. I’ve called customer services 3 times and eventually on Friday an engineer said it was a known issue and being investigated. I can’t force the compatible WiFi on to a specific channel as there is no drop down and is on ‘Smart (channel 11). Is there anything I can do? Any help would be greatly appreciated.
on 05-07-2026 11:57 AM
@Csarge That FW you are quoting version wise is the Fix, and all the other user's saying fixed now, would power off your EE Hub, 5 minutes should be long enough, Fixing the channel on the Main wifi then good chance your Comp will follow that, but you would need to wifi analyze it to see. Comp will not be allowed possibly for Fixed channel movement.
on 05-07-2026 06:51 PM
Thanks for your reply. I’ve powered down for 10 mins and restarted it. Main WiFi channel saying smart 36 and compatible saying smart channel 1. Hopefully, this will work. I’ll monitor it over the coming days and see what happens.
on 09-07-2026 08:47 AM
Can you confirm if this problem has been fixed at your end now? I am still having issues with the mini tv box dropping every few minutes and getting code IPC6023. When I called EE didn't mention that this was a known problem and just sent a new box which has behaved in exactly the same way! Would appreciate any help or guidance. Thanks
09-07-2026 08:55 AM - edited 09-07-2026 08:59 AM
@DottyR The EE Smart Hub 6 Plus version is the one that has been fixed for the FW update, you mention mini TV box was it that what was replaced for you? The error you mention above seems to be something for the EE Smart Hub 7 Plus version, is that what you have? If so looks like it has not been addressed possibly yet!
