06-06-2026 03:27 PM - edited 06-06-2026 03:30 PM
It is now pretty much confirmed that the recent (circa 25/5/26) firmware update on EE Smart Hub Plus (with Wifi 6) to version r4.26.1-R-1860948-PROD-83002 is causing a lot of problems around wi-fi dropouts, probably all on the 2.4 GHz frequency (and probably on both Main and Compatibility). The update was something to do with aligning BT and EE routers, no other details given.
Many people are suddenly getting random dropouts which were not there before, which temporarily stop after a reboot, particularly by powering down for at least 5 minutes. I personally also found our phones could not even see both Main and Comp networks when the problem was occurring. Almost universally, the fix is to go into the router Wi-Fi configuration page (Change Settings) and change the 2.4 GHz channel config from Auto to Fixed (many are using channel 6).
I have also seen a laptop reconnect every 6 seconds (to the 2.4 GHz Comp network) where I have tried all the usual - update Wifi adapter driver version, back off certain adapter sensitivity settings - and I even bought a new USB Wifi Dongle, which also would not connect stably. This laptop was absolutely fine before the update (as were the phones that were dropping off the wifi). We're now using that laptop on Ethernet-over-mains, somewhat less convenient but totally solid (and Amazon have refunded the Wifi Dongle 🙂 )
Today I had an excellent conversation with one of the EE Guides (using their callback system which imho is a pretty good way of getting hold of them) and he agreed I'd already done pretty much everything I or EE could do, and will escalate this.
He indicated that any sort of routine firmware update is unlikely very soon, but that they are aware of these wifi problems, and implied (or maybe I read into it) that an update can sometimes be rolled out to fix specific problems.
So I think the best thing to move this forward positively is for everyone to report the problem to EE. Text GUIDE to 66033 and they will call you back in usually less than an hour. The more who report, the stronger the case.
Before doing this it may speed things up if you do a Factory Reset on your router (under Advanced Settings / System) and then reconfigure it the way you had it before (e.g. turn Comp on, etc.) then check the issue is still there. We pretty much know this reset does not work, but the support team do have a sequence they need to go through and a Factory Reset is one of those steps, so doing this before will speed things up.
Thanks everyone - fingers crossed.
03-09-2026 09:52 PM
@Martyh1234 Unfortunate but there are issues then issues, stability of an EE hub can be one off those, and after a couple off hubs then time to look at what and say what is going on. Broadband problems can be caused by another device on the network, if you are past your cool off period, then complaints would be the way to go.
08-09-2026 03:00 PM
I am having exactly this problem
I am self employed. My training session today has been a car crash due to this and I won't be able to charge my fee. I am incandescent with rage. I have contacted EE 3 times to be told the same old guff. I have told them it's their router. EE m7st fix this AND pay my fee for lost work. I have no internal IT support. I am not technical. I am livid!
08-09-2026 04:06 PM
@FMcP Do the text to EE if on there latest system, HELP to 66033 and have them test your connection with a possible call back if they find anything.
