How do you block a specific website?
Be-45
10 REPLIES 10
FIZZYLP
Skilled Contributor
Skilled Contributor
Hello @Be-45
You can do this by clicking HERE.
Hope this helps!  If you like my reply and want to say thanks for the helpful answer then please click on the Kudos on left hand side  also if I answers your question correctly please let us know by clicking on Mark as Accepted Solution 
Thanks.  Where is this on the app?  There doesn't appear to be a section for it.  Or do I do this somewhere else?
Brilliant Contributor
@Be-45 What EE router do you have? And what EE app are you using?
Hello.  It just the regular ee app and the router says smart hub on it
FIZZYLP
Skilled Contributor
Skilled Contributor
You should be able to access the Hub Manager and manually block sites.
Ah right.  How do I access that?  When I entered the IP address I just got a lot of information with nothing I could see that seemed relevant
FIZZYLP
Skilled Contributor
Skilled Contributor
  • Open a web browser
  • Type 192.168.1.254 into the address bar (where you normally type the internet address; there's no need for www or http, just type the number directly into the address bar).
  • Press 'Enter'.
    But you have to be connected to the Hub itself.
Mustrum
@Be-45   I think you have been sent on a bit of a wild goose chase. The parental controls that was linked in an earlier post is only available for customers on the New EE network and with the Smart Hub plus.
Also you cannot block sites on the Smart Hub.
How long have you had your EE Broadband service?
If we're talking about the SH+, it has no Access Control facilities within its GUI, only via the EE app.
