16-12-2025 01:47 PM
We're aware of reports from Google Pixel 8 users who are having difficulties connecting their phones to the new Smart Hub 7 Plus.
When trying to connect your Pixel 8 to the hub's WiFi, you may find that it fails to connect at all, or connects very briefly before disconnecting.
We've established that this is a recent problem following the big December Pixel update - Android 16’s new updates
Our engineers have raised the issue with Google and we're hopeful the problem will be resolved in a future Android update.
In the meantime, you can work around the problem by having your Pixel 8 device use the Compatible Wi-Fi network. Steps for activating and using this feature can be found here - Set up and use Compatible WiFi | Broadband Help | EE
15-08-2026 12:10 PM
I'm pretty heavily into Google's eco-system and my personal experience with their support desks isn't all roses to be fair. It's not unusual for first/second line helpdesks to be detached from the more complex issues - just one of those things I guess 🤷
I had an issue with a new Chromebook recently where it outright refused to connect to 6GHz WiFi. I raised the issue via the Google bug tracker/provided logs etc. and wit a bit of persistence it was fixed in a ChromeOS update. I'm fairly certain if I'd gone through Google's frontline support teams, I'd have got nowhere 😉
Anyway, in the absence of an update, there is another potential solution if you don't want the hassle of using Compatible WiFi. Instead, you can try changing the security of the default WiFi network to 'WPA3-Personal-Transition'. This is a more established security method that the Pixel devices should have no problem handling. There are a few things to be mindful of though: -
15-08-2026 12:50 PM - edited 15-08-2026 12:50 PM
I've probably been confused by the differences between WPA3-Personal-Transition and WPA3-Personal-Compatibility on the 7+ but I've most devices connecting to an Asus AP. I've just one device that won't see an SSID in WPA2/WPA3 mode and for that Compatible WiFi on the 7+ with WPA2 only on 2.4GHz works fine. Most devices work fine on 5GHz with what Asus names more clearly as WPA2/WPA3 as a few devices don't support WPA3 - but a Pixel shouldn't have any issues with WPA3 on Android since 10. Picking up 6GHz is another matter - my Pixel is the worst of a few 6E capable devices at seeing the 6GHz SSID - it usually just re-connects on 5GHz using WPA3 and doesn't drop - in any case the speeds on 5GHz (plus better range) are Ok for day to day use.
15-08-2026 07:12 PM
16-09-2026 09:57 PM
I am having this issue now so still hasn't been fixed, connects to my home WiFi for few hours and disconects, I have to keep resetting connection all the time very annoying, was fine with BT internet but since switch to EE just keeps disconnecting
17-09-2026 06:59 AM
@Sue19692006 Just put the BT Hub back on the connection, that works fine with the EE Service.
13-10-2026 04:05 PM
Had cause to recheck this one recently and unless I'm mistaken, the issue looks to be resolved following the October Android update. At least on a Pixel 8.
Anybody else with a Pixel 8/9 in a position to confirm?
17-10-2026 03:11 PM
I set our router back to Compatible and haven't noticed any issues on my Pixel 9 Pro. So, yeah. Seems to be fixed. 🙂
