06-10-2025 03:55 PM
I’ve just installed me EE broadband kit, upgrading from BT. All gone well so far. Good broadband connection, TVs, printer, PCs successfully operational on WiFi. But the Hybrid Connect box shows 3 solid red bars. It has connected to the hub with a solid aqua light. I’ve reset factory settings and tested in 4 rooms of the house including attic. EE describe my postcode as having excellent 4G. What now?
08-10-2025 12:13 PM
New box arrived this morning. All connected and works a treat.
06-10-2025 05:11 PM - edited 06-10-2025 05:15 PM
@TheTelstar If you believe the 4G is good indoor/outdoor and have a connection then you may wish to see the sim chip is inserted correctly in the Hybrid unit as a push in until it clicks in place! It is also a special sim chip so you are aware!
06-10-2025 05:12 PM - edited 06-10-2025 05:16 PM
@TheTelstar wrote:EE describe my postcode as having excellent 4G.
Is that the Coverage Checker for what EE expects to be there normally or the Status Checker for checking temporary issues?
You could consult Check service in your area to see if any mobile network faults are being attended to in your local area.
06-10-2025 10:35 PM
Thanks for your response. I tried to eject the sim but it seemed jammed. I had a call from EE support later and he agreed that it was a faulty or incorrectly inserted sim. He has arranged a replacement.
07-10-2025 08:14 AM
Thanks for the update here @TheTelstar.
I'm glad to hear that our team managed to help you get a replacement sorted, and I'll keep everything crossed that this helps resolve things.
Please keep us posted on how you get on, too.
Peter
08-10-2025 12:13 PM
08-10-2025 02:22 PM
@TheTelstar That's great to hear, thanks for coming back to the community to share for anyone else who may have a similar issue.
Alex
17-10-2026 02:04 PM
ive 2 replacments and still same issue?
thx
17-10-2026 02:19 PM
@mb19751 What issue, have you followed what was on the thread so far?
17-10-2026 02:30 PM
flashing red signal on hybrid 2 replacement tired all solutions still same
