EE broadband app WiFi controls spinning
Huggons1
EE broadband app WiFi controls spinning, when attempting to setup in app
EE executive complaints team say that this is a known issue and affected customers (around 1000 affected customers app version 5.75.0) will have to wait for an app fix to resolve the issue.
Still not resolved in update 15/12/2025 app version 5.76.0. 5.76.0.was released today for both iOS and Android.
Same issue on IOS and Android. Just spinning, when attempting to setup wi-fi controls. Issue ongoing for months. Broadband support helpline not even aware of the issue and took a complaint to acknowledge the fault.
Hope this helps someone.
34 REPLIES 34
JordanTA
EE Knowledge Specialist
I'll drop you a message @Huggons1
Huggons1
Thank Jordan, I have replied back to your message
I am having this exact issue, been with EE for 18 months and had my new hub 7 delivered today but when trying to activate WiFi controls I get the endless death spin
Huggons1
You need support to raise a fault over to TMC Operations, Technical Management Centre,
Newcastle-Upon-Tyne, to get the issue resolved.
Good luck with getting first line support to log this over
Daymoalexander
Valued Contributor
Valued Contributor
Have had the same issues. On part fibre 67 ultimate. Working fine until 2 days ago. Still in my first 14 days but don’t really want to switch again! Have logged  complaint, annoying as I can’t access via the hub manager either and my set up was done using Ethernet cables as I can’t see the app controls.
Login to your EE Smart Hub/Router at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router.
I can’t access this on my iPhone and it doesn’t seem to like it on the iPad either. Any further advice?
You might need to do the secure  https://192.168.1.254
I have tried that just seems to take forever to load. Could be the part fibre connection speeds tho. I can get in, but once I’ve entered the router admin password, I just get a rolling circle
