Changing DNS on fibre router
jhehffery
Hi All,
I am looking to change my DHCP settings to set client DNS devices to my DNS server.
Currently it is set to my router but I cannot seem to change this. Under "My Network\IPv4 Configuration" there is no option, but when I search for "DNS", it takes me to this page.
Any advice on how to change would be greatly appreciated 🙂
@jhehffery : Which router? Sounds like the white Smart Router.
If so, on that page, Advanced > My Network > IPv4 Configuration, isn't there at the bottom DNS Servers / Auto that you can set to "NO" & then fill in your 2 DNS's?
bobpullen
Star Contributor
Star Contributor
@jhehffery - if it's a Smart Hub Plus it's not currently possible.
Sorry for the reply, it is the Black Smart router
Looks like i have to use PiHole/QNAP for DHCP 😞
