Broadband Upgrade
Lyn67
Why is it taking so long to upgrade my broadband? I was told 48 hour max, 7 days ago!!!!
manatarms84
Expert Contributor
Expert Contributor
No one here has access to your account - there are different reasons why it may be delayed.  If you are upgrading your speed but without changing technology as far as I can tell it should be fast as you say.  I would contact EE who will be able to have a look at the order and see what the updates are - or you can try tracking your order online which may give you some insight as well
manatarms84
Expert Contributor
Expert Contributor
Christopher_G
Hi @Lyn67
Welcome to the community.
I definitely recommend following @manatarms84's advice and speak with our Customer Support team. They'll be able to check your order from our side.
