close
Wifi Disc
BWhite_
Is there a way to remove the WiFi Disc stand so it can be wall mounted?
15 REPLIES 15
Using the slip out piece of plastic on the back of the disc i prised the disc apart just enough to undo the internal screw. The leg then falls off. The disc then snapped back together and now can be wall mounted on a screw.
Sent from my I phone 11
Thanks for your advice. It worked.
I just had the same thoughts about this leg.
As it turns out, I wall mounted it and the legs held the body away from the wall. As it is mounted directly above the electric socket, the legs provided a handy shelf to tuck away the additional electric lead.
Mustrum
I hope you had something to trace where the electricity cables went before you started to drill into the wall?
The warning is here for anyone else who may try and do the same!
Sockets usually come from below; light switches from above. However you would always check it out 1st. There are tools for this.
Hi
I al also trying to wall mount a couple of these discs.  I gently prised the feet off the disc and they came away very easily - not too much force, the feet sitting in their open position.
However my problem with wall mounting is the actually get a power supply to the dics which does not push the disc out from the wall as the supplied BT one does.  Any suggestions please?
