close
Wifi Disc
BWhite_
Is there a way to remove the WiFi Disc stand so it can be wall mounted?
15 REPLIES 15
Leanne_T
Hi @BWhite_
Do you have Smart WiFi?
If so, our Setting up Smart WiFi Help post, has full information for you 🙂
If not, which router do you have?
Thanks.
Hi @Leanne_T , the "Setting Up Smart WiFi Help post" does not answer this question. How do you take the legs off the unit so that you can wall-mount it? I also need to do this but can't find any information about it online.
thebenhanson
I need to wall-mount this unit but cannot figure out how to take the legs off. There is a small grey rubber plug on the bottom, if you remove it, you can see through the gap that there is (what appears to be) a screw holding the legs on. But, you'd need to be able to pop open the case to do this...has anyone had any luck removing the legs/stand?
EE Community Support Team, please don't answer by linking to the "Setting up Smart WiFi Help post" as it does not say how to remove the legs/stand.
Leanne_T
Hi there @thebenhanson
I have spoken to the relevant team and they have advised they are fixed in place and removing these may cause damage to the unit.
Surely this isn't right... there is a mounting point, suggesting that the disc can be mounted on a wall. But the feet make the bottom half of the disc stick out a huge way. Looks unsightly, and likely to fall off the wall.
Christopher_G
Welcome to the community, @DutchieDo.
This is what we have been advised by our device specialists.
Hacksaw them off. Rawl plug a screw. Hang the disc. Staple the wire to neaten it up. Job done
it looks this is the only option. i am surprised that you cannot wall-mount this unit.
By chance, did you figure it out how to do it?
