close
Start my pack early
Rustic17
I have spent over half an hour trying to do this, texting NOW to 150, then AL to 150, but still hasn't worked. It must be simpler than this?
23 REPLIES 23
@Ssykes1 : Can't you just buy the same pack early & then text NOW to 150. After all it can't start until you've bought it. Otherwise you won't buy it until the current pack expires.
JBvillain
I have the same problem, did you manage to find the solution? I am on DATA1 which doesn’t exist in all packs anymore, but I have accumulated a lots of boosts that I don’t want to loose
@JBvillain : You don't lose your legacy boosts when you switch to a modern pack.
You can no longer start a legacy pack early. You either:
  1. Keep on the same legacy pack: Wait till its expiry date even when some of its allowances have run out & then buy the same legacy pack. To tide you over in the meanwhile you could buy add-ons, OR
  2. Switch to a modern pack: Buy a new pack & then texting NOW will start it immediately, forsaking the legacy pack for ever.
