Moving from BT to EE (SIM only, and Broadband)
charleshking
Good morning all.
I'm moving to EE from BT (a family pack of 4 SIMs and a Broadband Fibre Plus plan)
My Broadband switchover date is the 23rd of November.
I've a few questions 🙂
My four SIMs have arrived already, I have my PAC codes from BT, and I'm wondering if I should activate my EE SIMs right away and start using them, or wait until 23rd?
What's the process for getting the smoothest switch-over of our existing mobile numbers?  I've seen the 'Transfer My Number' guide - is it simply a question of living with up to 24hrs of our mobile numbers being different until the transfer kicks in?  Or should I revert to the BT SIM while that process happens?
I have 4 SIMs which are labelled with four new numbers (I guess allocated by default) does it matter which SIM goes in which phone? I don't see anything to indicate a correspondence with existing numbers.  Incidentally, the PAC numbers from BT are the same for all four of our phone numbers.
If I do activate my SIMs now, will I end up with different billing dates for Mobile and Broadband?
Finally, one of the SIMs was sent by courier, and the other three by post - which seems odd.  Is that usual?
Many thanks for any guidance (while working from home, I'm keen to minimise down time!)
@charleshking :
  1. Your BB & its go live date have no bearing on your SIMs & the porting of their nos. They are independent of each other.
  2. Billing for BB & mobile are entirely separate of each other. However you can arrange with EE to be billed on the same day of the month.
Blimey @XRaySpeX you're a) swift and b) everywhere!
I'll get cracking on the SIMs, then 🙂
Thanks! You're welcome 🙂 ! Glad I could be of assistance.
