close
Speed is shocking so slow
Ann1959
I've just upgraded my package on the 8th June and Internet was fast could stream at 4k and everything then all of a sudden Internet slow again same as my last package im sure its something to do with the exchange or green box I'm connected to I'm providing photos of my speed and bt wholesale checker
openreach engineer attended property found out that they used to be a second telephone socket in house and council (we live In a council house) cut the socket off and plastered the walls, over the wiring and left the original master on the wall to top that off the wiring out side had a small cut in it and the indoor wiring was under the carpet under metal carpet grippers 😞 so openreach openreach replaced the broken bit of wiring outside and renewed the indoor wiring and gave us a new master socket with separate broadband and phone ports now Internet is faster than ever. 👍
30 REPLIES 30
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
Mustrum
Something or things not right there,
It maybe that your line has been wrongly provisioned, but the BTW DSL page shows a "Bridge Tap" which is often an indication of an internal wiring problem.
Are you able to plug the router into the Test Socket - revealed buy removing the two screws, or unclipping the Master Socket faceplate?
Also sight of the advanced router page would help.
  • I haven't got a pc with ether net but on the ee home app my speeds are 10 down 2 up at router
Event Log is not wanted; only the Information tab.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
What did you upgrade from/to?
Removed faceplate and connected son in laws ps4 to ethernet ran speed test 8.9 up 1.5 down
  • From bright box 2 with the fiber to cabinet
  • Reboot router speeds are 8.6 down 1.3 up
  • No extra wires connected to faceplate socket is master socket 5c
