For up-to-date information and comments, search the EE Community or start a new topic.  |
01-04-2021 06:54 PM
I have a Samsung S8 and after 3 years of trouble free use I have a problem. I dropped the phone from waist height onto its corner, nothing broken and phone continued to work. During the day though the email app (the Samsung one) started to play up, dropping shortly after opening so I can't use it. I also tried installing Outlook but that did the same. It has been suggested to me that I should do a factory reset but there is also a phone reset option which I think is less dramatic. Can anyone advise me the vest thing to do please?
01-04-2021 07:05 PM
Phone reset and factory reset is the same thing just called different in the settings menu
01-04-2021 07:09 PM
01-04-2021 08:08 PM
Who is your email provider? What have you put as the Incoming Server settings (all of them) in your Mail app, obscuring your name?
01-04-2021 08:14 PM
01-04-2021 08:17 PM
Are you still with BT broadband?
01-04-2021 08:19 PM
Cuz they still be wrong or at least not appropriate for the EE network. That's the usual cause. Let's see them & I'll be able to tell you. Don't assume!
01-04-2021 08:20 PM
01-04-2021 08:29 PM
02-04-2021 08:29 AM
Factory reset could be the way to go with this, @BobPriston.
Just make sure you have all of your information backed up first.
