29-03-2021 11:45 PM
I have unlimited data usage and today my 4g stopped working. It’s quite annoying as I use it travelling to and from work and within work aswell can someone help me find a solution??
30-03-2021 07:58 AM
Morning @AaliyahMiah02
Can you make and receive calls and texts?
Which phone are you using?
Speak soon 🙂
05-04-2021 04:25 AM
hello there ,
easy step - can you open up " gov.uk " or " nhs.uk " if the answer is yes
the next step is to call customer services who should if the they are on there toes walk you though the next steps
Good luck ....
