20-06-2021 08:41 PM
About 25% of the time I open the camera app on my S21 Ultra it just opens a black screen with no picture and occasionally restarts the phone.
I have tried deleting the data cache on the app. I have rebooted the phone. Yet still it continues.
I suspect its a hardware fault but does anyone have any thoughts about how I might fix it?
29-07-2021 03:46 PM
Just putting this here in case it helps someone else:
The Camera and Gallery aps are both connected to each other - if you open Camera it shows the last picture taken for example. I deleted the cache of GALLERY then the Camera app started working again!
I tried everything like turning off then back on, safe mode, hard reset back to factory settings. I then reloaded my backup which, of course, loaded the old cache from Gallery so put the problem back in place. Simply deleting the gallery cache would have fixed it. 🙂
21-06-2021 08:11 AM
Hi @KeithS21
Thanks for coming to the community about this.
I hope you're well and having a nice Monday, are you up to much?
I use the camera on my phone loads, so totally get that this needs sorting.
Do you have all the latest software for your phone downloaded and installed?
21-06-2021 07:54 PM
Hi Chris. Yes all updates are applied. The camera was working fine before the last update with camera performance updates!
I believe there is another update soon? Perhaps that will fix it.
22-06-2021 08:13 AM
Have you tried backing up your Samsung and fully restoring it to factory settings, @KeithS21?
This can help with software problems that occur after an update.
29-07-2021 03:46 PM
29-07-2021 04:02 PM
