close
Overheating
AndziaAbi2017
My iPhone keeps over heating  every time I connect to WiFi
I’m still on contract no insurance just eligible for 3 mot
what are my options
epicrhxdes
Hi @AndziaAbi2017
I would actually recommend taking advantage of that free device MOT. I wasn't going to use it myself but then realised it was a useful tool and as it came with the contract then why not?
Go ahead with it, they might be able to tell you what's wrong with the device? What iPhone is it, and where about is the overheating on the device?
Thanks! Have a good day!
@AndziaAbi2017  How long have you had the device for ?  If it’s under 12 months Apple provide the warranty on the device so will look at it and if it’s faulty will exchange the device.
you can use THIS.
Apple will request that you first try factory restarting the device first.   Make sure you do a backup of your device first though.
That should say “factory resetting”.
