close
No internet outside
Joanna8712
Hi all. I've changed to EE 1st of March. I received new sim and I transferred my number from another brand. I have pay as you go with 4G data and iPhone XR. Unfortunately when I am living my house I have no internet (no Google, no WhatsApp etc). I can call. I have software updated, I reset network settings but still same problem. Phone is showing all the time 4G and is no network problem in my area - I checked.  Does anyone has same problem? Or can help? I don't want to keep paying for something what is not working.
12 REPLIES 12
Hi @Joanna8712
Is mobile data enabled on your phone?
Are you using iOS or Android?
Hi @bristolian ,
yes data is ON.
I am using iOS.
PAYG users need to have an active data pack in order to use mobile data - do you have one?
Text BALANCE to 150 (it's free) to check.
Yes of course, still 2.3G. When I reset network everything was fine that day. Then I came back home, turned to WiFi, left home again and no network again but was showing 4G on the top all the time.
Jon_K
Former EE Employee
Hi @Joanna8712.
Have you been able to use data at all since getting your pay as you go SIM?
Jon
Yes. Now I am at home, I switched from WiFi by myself and is working. And was working outside after I reset network settings. But when I am living home with WiFi on and is turning automatically to the data is not working. I can go for walk like that and no internet but if I reset network settings in the park for example starts to work.
Jon_K
Former EE Employee
Thanks @Joanna8712.
So it works sometimes, but not all the time?
Is this location specific?
Does it only happen at home?
Jon
Correct but usually outside - can be high road or park, doesn't matter. At home I am using WiFi generally.
Jon_K
Former EE Employee
Thanks @Joanna8712.
Can you check our Network Status Checker to see if there is any ongoing work in your area?
Jon
