close
My internet service is not working for weeks and day in and out all time
Lauraspencer25
I have be with you for two years internet service as never worked as it should I can go day with out service it's in and out never stay on long
Is it the BB as a whole dropping or just the WiFi connections? What colours are the light sequence when it happens?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
