For up-to-date information and comments, search the EE Community or start a new topic.  |
17-05-2021 10:31 AM
Hi, when I give my PAC code and old number to EE, using the 07********* format, they get an “invalid CTN” error. They say this means the pack code is valid, but the mobile number isn’t.
If they enter the number in the format 47*********, because the PAC was generated against +447*********, it is accepted, but the port fails.
EE have insisted the number being ported in must begin with 0, my old provider has insisted that’s not the case and that the number and PAC are both correct.
a Google search gives plenty of info re the correct PAC code format for porting, none about the correct number format for porting.
I'm now piggy in the middle, paying two bills. Both providers have opened cases, but continue to blame each other.
Any thoughts at all about how to move this forward would be very gratefully received.
17-05-2021 02:48 PM
17-05-2021 02:56 PM
Yes, but all they’ve said is the port failed and they need 11 digits. Three can’t give 11 digits, so that’s me stuck with two contracts and a second line (dual SIM) that’s no use at all to me.
Waiting on one more reply from EE, then I’ll try the “port to another network, then back to us” idea, but EE had better cover the cost of doing that.
17-05-2021 03:13 PM
Hi @Southdowns,
Please let us know what happens once Customer Care get back to you. I've never seen an example of this issue before and I'm sure the porting team will be able to resolve it for you.
17-05-2021 04:28 PM
Of course they can! All they gotta do is knock the '+44' International country code prefix off the front & replace it by a '0' to give a standard UK mobile no. '07*********', just like the rest of the country would.
17-05-2021 04:49 PM
No, they can’t, at least not on a technical level, because the PAC code is tied to a 12 or 13 digit number.
Now, they can give an 11 digit number, and have done, as long as EE interpret it correctly back to a 447 number to get it ported, which it appears they can’t do. The fact remains though, that because EE’s system appears not to have that flexibility and is absolutely literal about using what you enter, and can only accept 11 digits, 07 will fail. In other words, you can’t apply 11 digits directly to a PAC code; you have to “convert” the formatting first, which is what EE appear to be failing to do.
I can see this very clearly now that I’ve followed customer services’ suggestion of porting to another network in order to then port back to EE. Vodafone accepted +447********* when I gave them the PAC code, interpreted that as 07********* on the confirmation page they served up, then put 447********* in the confirmation text they sent me.
if the port now goes through with Vodafone, that will show me that they are able to take the number in whatever format you choose to give them (11 or 12 digits, or 12 with the + sign, maybe even 0044), and correctly interpret it into the format that the old network has tied the PAC code to.
that will beg two conflicting questions - why can’t EE do it right, and why isn’t everyone having this issue?
My big fear is that the port works TO Vodafone, but won’t work FROM them to EE, if they also expect to receive the request in the correct format.
