G Fast question
bulldog147
If I placed an order with EE, does it come with EE Hub router support G.fast or will it be openreach certified engineer to attend the property to install g.fast socket and openreach g.fast modem?
My plusnet contract exprired next month still on FTTC 80/20 with them.
G.fast Range A (Clean)259.8188.539.518.3164.5AvailableAvailable--
G.fast Range B (Impacted)215.6154.227.313.6140.4AvailableAvailable--
27 REPLIES 27
bulldog147
Can I use my own router (will EE provided me broadband username and password for PPPoE login)?
Will EE including free Static IP Address?
Look like G.Fast 160/30 are the only way now from 80/20.
Yes, in Home Broadband settings you'll find almost everything you need to set up your own router. What's missing for Fibre is:
  • VLAN ID = 101.
EE don't provide static public IPs. That's a rare benefit you get from PN, a static IP for a small 1-off outlay.
bulldog147
Will EE provided PPPOE username and password for setup my own router as most ISP refused to give our broadband usrrmame/password as I do have my own G.fast router
You can get them from the supplied EE router when you 1st connect.
bulldog147
Thanks. Just ordered it. Cheers
bulldog147
One more question
I order G.Fast fibre 100 without landline as I never use any phone calls. It say below:
The only difference is you won’t have a home phone service on your landline and if you try to plug one in, there won’t be a dial tone. You also won’t have a landline phone number as it won’t be possible to make or receive calls on it.
What happen if I put BTw Checker with no phone number on it because otherwise I would not see below:
BT-Broadband
and also via BTw speedtester for checking phone number for IP Profile etc.
BTW-Performance-Tester
Without no landline phone number will cause problem not to get any information via BTw checker and BTw speedtester?
You can still use the BTw Availability Checker & the BT Speedtester when you have Fibre W/out Landline Number by obtaining your  Access Line ID (ALID) , Broadband Service ID (BBEU) & UPRN from your ISP.
bulldog147
will ee provided me Access Line ID (ALID) , Broadband Service ID (BBEU) & UPRN. They might ask me why you want this for?
Maybe I cancel the order and re-order to kept my landline number but just pay as you go.
Yes, they expect such Qs. I have EE Fibre W/out Landline No. & got these parameters easily from CS.
bulldog147
I have decided not joined EE but go with UnchainedISP.
On the May 25th 2021, just switched over to UnchainedISP for my G.fast service 160/30 with line only (no outbound call except emergency only on 999) from Plusnet VDSL2 80/20 since 2014.
Connected to Openreach Gfast Modem (ZT Link MT992) with TP Link VR2600 Wireless Router.
Engineer test the line for earth test and voice incoming calls test and outbound emergency call - he didn't dial 999
and all passed ok.
Engineer went to the cabinet to changeover from old provider plusnet FTTC to new provider unchainedisp GFAST.
Engineer connect his test kit to the test socket and was reading 159.88 Meg downstream rate 29.66 Meg upsteam rate with max rate on the line is 210 Meg down and 29 Meg up (no chance of 330/50) good job I choose 160/30
Today the isp give me full control on my account with useful control broadband portal with all information on it eg: TalkTalkBusiness upcoming and past maintenance work, Sync Rate Profile current and past, Session History current and past, real time firebrick latency & throughput statistics, Line speed limited (full control of the line speed from 0% to 100%), Carrier Notifications, Request IPs, Reverse DNS, PPP Password, billing portal, customer service, my profile and router settings. Coming soon more feature to be added: Line Test, GEA Test.
UnchainedISP have two products are:
G fast 160/30 at £49.99 12 month contract with backhaul TalkTalkBusiness with Static IP Address (free installation & setup fee) supplied with Openreach Gfast Modem (customer must have their own Router)
G fast 330/50 at £56.99 12 month contract with backhaul TalkTalkBusiness with Static IP Address (free installation & setup fee) supplied with Openreach Gfast Modem (customer must have their own Router)
Can do BTw backhaul as a option request to the ISP as it might charged extra but all Gfast products come at the standard backhaul TalkTalkBusiness by default!
Here is tracert bbc.co.uk test below:
Microsoft Windows [Version 10.0.19043.985]
(c) Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>tracert bbc.co.uk
Tracing route to bbc.co.uk [151.101.0.81]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms ARCHER_VR2600 [192.168.0.1]
2 12 ms 10 ms 11 ms 185.250.8.239
3 12 ms 12 ms 12 ms 185.250.8.238
4 13 ms 11 ms 11 ms thn.as51561.net [46.102.193.75]
5 12 ms 13 ms 12 ms be4482.ccr21.lon01.atlas.cogentco.com [149.6.184.181]
6 11 ms 11 ms 11 ms 149.6.2.38
7 11 ms 12 ms 11 ms 151.101.0.81
Trace complete.
Added: Here is dslchecker before FTTC 80/20 and now GFAST 196/28* via Openreach Gfast Modem (line capped at 160/30 product) https://i.postimg.cc/gjHtF9nL/BT-Broadband.jpg
*Openreach Test Kit 210/29 from the test socket: https://i.postimg.cc/SNKfNYPv/gfast-openreach-line-test-25th-May-2021.jpg
ZT Link Openreach Gfast Modem MT992: https://i.postimg.cc/mZ9t3LHg/Gfast-Modem.jpg
Here is real time live BQM from my new ISP - UnchainedISP G.fast 160/30: https://www.thinkbroadband.com/broa...hare/54f36b90b989b8f3327cef40cf5907873729e42f
TBB Speedtest: https://www.thinkbroadband.com/speedtest/1622196354461598955
