close
Data Add On
DawnBelton
Puzzled … my boyfriend usually has the option to buy / add on extra data so he can gift it to his son as and when needed.
the option to buy add ons has disappeared!
we are puzzled after much searching and googling
any ideas about what might have happened ?
many thanks in advance
dawn
Is he abroad?
I’m having the same problem as Dawn’s husband. I’m currently in France.
Hi @Wh71
I hope you're well and having a nice time in France, other than this issue of course.
When you're outside the UK data you can buy is roaming data, and that can't be shared.
@Christopher_B : France is in the EU! You don't buy roaming data in the EU. You use your UK allowances or buy UK add-on data there & you should be able to share it. This is no Solution!
Leanne_T
Hi @XRaySpeX
Thanks, this has been removed now 🙂
@Wh71, have you ran out of data to use in France?
Can I just check, do you have a pay as you go or pay monthly account?
