App connection
Hammer63
Why wont some of my apps open, ie bank,amazon
stuarttunstall
Skilled Contributor
Skilled Contributor
Google did an update and screwed the system, I had the same issue with Samsung Email app this morning...
https://www.bbc.co.uk/news/technology-56496783
https://www.cnet.com/news/gmail-and-other-android-apps-crashing-on-phones-heres-googles-simple-fix/
https://www.androidauthority.com/android-apps-crashing-1210994/
To name a few...
If you go to app store and update Google chrome you should be OK, worked for me and a colleague at work...
You will find that Android system webview   will already be disabled, just update Chrome.
stuarttunstall
Skilled Contributor
Skilled Contributor
To name a few...
Have tried updating both chrome and Google Web view cam and won't update either. Should I try uninstalling them then reinstall?? Have run out of ideas!!!
Apparently you have to go to app store anduninstall the webview not updateSent from my Galaxy
