06-06-2020 10:02 AM
I have the above 4G Router and ever since I've had it I can only plug in a PC to the LAN port.
I have a TPLINK 5 port switch that all my other devices connect to and with my 3 4G Router I can plug that into the switch and everything works.
I can't find any specifications that say whether the EE router supports a switch plugged into it rather than the PC direct.
Can anyone shed some light on this?
Dave.
06-06-2020 12:46 PM
Hi Dave. Firstly, I have a 4G Router and my PC connects from either the LAN/WAN or LAN2 ports. As I had a spare Zyxel switching box in a drawer I did try it out - again either port out from the router connected to the Zyxel then to the PC connects without any problem. Hope that helps.
06-06-2020 01:09 PM
Yes thanks, now I know it should work I can contact EE Support to get it looked at.
