28-07-2023 03:48 PM
I've taken my sim out and inserted it in a new phone, still doesn't work.
Called ee and automated response said my number does not exist but calls can only be made through WhatsApp.
Need to fix this in order to revieve texts!
Please help 🙏 @XRaySpeX
28-07-2023 05:39 PM
Then you've lost it completely by not using it for so long.
EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then had a further 3 months to call EE to reactivate it before it is lost completely.
You needed to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
28-07-2023 03:50 PM
@Sallymcdonalds : Is it on contract or PAYG? When did you last use it successfully?
28-07-2023 03:52 PM
Are you in the UK?
28-07-2023 04:19 PM
It's pay as you go and last used it successfully July 2022
28-07-2023 04:19 PM
Yeah- England
28-07-2023 05:16 PM
Hello @Sallymcdonalds.
Thanks for confirming.
If your SIM was last used one year ago then it is likely the number has been disconnected.
Please see our pay as you go hibernation post HERE for more information.
Katie
28-07-2023 05:39 PM
28-07-2023 06:39 PM
Is it impossible to get my PAC code bc I wanna keep my number?
28-07-2023 07:01 PM
Yes, you have no number to port.
