on 13-10-2024 12:42 AM
Hi all,
So I took my phone to Hyderabad, India. I can use it with Wi-Fi.
But I’m unable to get any phone service, I want to receive a code to access a few websites. Eg: code so I am access google mail
It’s nothing to do with roaming and I have turned my phone off and on
I want onto network selection and I can’t automatically connect to any networks. I tried selecting air tel it briefly connects and then disconnects. I still can’t use my phone
Any help would be appreciated
Solved! Go to Solution.
on 13-10-2024 12:50 AM
Your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. What's the basis on which you say "this is nothing to do with roaming"?
on 13-10-2024 02:06 AM
It's everything to with roaming.
on 13-10-2024 03:23 AM
Thank you for your reply.
I’ll call them and set up roaming.
As I said to the previous post: I’ll call them and set up roaming.
