Data in the EU
Bookman
I’m currently in the E U. I have an account with EE but can find no way of purchasing 4G roaming. I’m probably missing something very basic but can someone help please?
On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK.
6 REPLIES 6
Katie_J
Hi @Bookman.
Thanks for coming here.
Are you a pay as you go or pay monthly customer?
Katie
I would pay monthly in the U.K.
Katie_J
Thanks for confirming @Bookman
Did you enable roaming on your account before leaving the UK?
This could be done by texting ROAMING to 150 or by giving us a call.
Katie
No. Does that mean I can’t do it now?
Katie_J
Hi @Bookman.
Our customer care team can activate this, however, you would need to call.
Do you have access to Skype? Our customer care team can be called that way over WiFi if you do not have access to another phone.
Katie
