Mobile data add on not working
Angiesue
I use pay as you go and bought a mobile data add on but it’s not working.
Bought before and they worked fine, so what’s changed as now won’t work.
Christopher_G
Hi @Angiesue
I recommend speaking to our Mobile Care team so they can look into this further for you.
13 REPLIES 13
What does texting AL to 150 from your no. fully report verbatim (it is free)?
Angiesue
Thanks, I was wondering if I have a 3G sim,  and as 3G is getting faced out I now need a 4G sim to use mobile data.
Anyone had the same problem?
Katie_J
Hello @Angiesue
Is your SIM an EE pay as you go SIM?
Does your phone show as connected to 4G?
Katie
Hi
it doesn’t show 3G or 4G at the top of my phone. My 30 days to use my data is running out and I haven’t been able to use any yet.
Katie_J
Hi @Angiesue.
When did you get the SIM you are currently using?
What does texting AL to 150 report?
Katie
I got the sim 4 years ago.
sent AL to 150 yesterday and it tells me my balance and
 You have 5.0GB remaining until 03/11/2023 for your 5GB data to use in the UK for 30 days
Katie_J
Thanks for confirming @Angiesue
The SIM will connect to 4G.
Are you able to make calls and texts OK?
Could you confirm if you are in the UK?
Katie
You have your full 5 GB data remaining but are not using it. Are you outside the UK?
Yes I can make calls and message and am in the uk.
i just text ADD DATA to 150 and got the following message I am not on a plan just pay as you and don’t want a plan.
EE Packs are not available on your current 3GEE plan. To upgrade to a 4GEE Pack you will need a new 4G sim and 4GEE Price Plan. If you're interested please visit your local EE store or dial 150 from your phone to discuss your options.
