Wi-Fi Calling working for iphone users but not android
anthony2024
Hi
I have a strange issue to resolve.
We have several devices all on EE, some iphones and some android (samsung and google).
We are in a poor signal area so rely on Wi-Fi calling, for some reason all android phones cannot connect to Wi-Fi calling but iPhones can.
Anyone know why that would be?
Just to note all devices  are connected to the same network.
Thanks in advance
9 REPLIES 9
Leanne_T
Hi @anthony2024
Thanks for coming here 🙂
Do the phones have WiFi Calling turned on in the settings?
Can they find the WiFi network and connect?
Also, does WiFi Calling work on any other WiFi network?
Speak soon 🙂
Hi Leanne
Yep all the phones have wifi calling on and have a strong wifi connection.
As i mentioned iphones work but android do not. Even tried the airplane mode trick and turning wifi back on but no difference.
I did some testing with various sims and O2 sim also didn't work but a Three sim did on the same phone.
Any ideas?
Leanne_T
Thanks for coming back to me @anthony2024
Are you able to try and connect to a different WiFi network?
Recent Android phones have an option to toggle "WiFi-preferred" cf "Mobile preferred".
Yes they work on other networks, feel as though something is blocked and I need to unblock it on this particular network.
But why would it work on iPhones and not on Android, and then work on Three but not on EE or O2?
Just a strange one.
Anthony
Thanks for the message, yep they have Wifi Preferred.
As mentioned to Leanne I did the airplane mode trick so it cuts off mobile connections and just wifi only. Works on iphone not on android, works on Three not on EE or O2.
Leanne_T
Hi @anthony2024
It may be worth calling our tech guides on 150 they can check WiFi Calling is fully set up for the numbers in question 🙂
Thanks for that will give them a call anyway to see if they can help but like I said it works on other wifi networks.
Leanne_T
The team will certainly get this looked into for you @anthony2024
Leanne 🙂
