Roaming Brazil not working
nayara_dantas
I landed in Brazil last week and I changed my plan recently to “All Around” 24m commitment contract to get things easier, but my pay as you go plan was working better then this commitment plan.
Here in Brazil I simply don’t have any signal, I can’t make calls, receive SMS, use data, nothing…  only Wi-Fi doesn’t allow me to connect with EE, to call abroad, EE doesn’t  have live chat or WhatsApp service, nothing…
I need to use my phone asap and I can’t find any way to get access.
@nayara_dantas : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
