Calls not working with travel pass help
Lusafi
Hello, im currently in turkey and activated roaming and also have travel pass for 7 days, my data is working but calls do not connect! Why is this and how can i use my calls minutes?
Have calls worked since you arrived in Turkey?
Are you able to manually select alternative Turkish networks, and do you have the same problem on each one?
