25-08-2026 01:33 AM - last edited on 25-08-2026 07:57 AM by Leanne_T
I need to use WiFi calling but it's not appearing at all
I have followed all advice (resetting, rebooting, airplane mode on and other unexpected advice)
I absolutely need WiFi calling as I have never had reception where I live.
This is an unacceptable situation.
25-08-2026 11:12 AM
Hi @Nomis
What device are you using? Is you WiFi network showing in your device settings to connect to the Wifi?
Speak soon.
25-08-2026 02:17 PM - edited 25-08-2026 02:18 PM
@Nomis Have you tried restarting the router? Switch it off for 30+ seconds before you restart it And to check you have got WiFi calling enabled on the device?
