on 10-04-2022 01:25 PM
Did you get it sorted?I am having the same issue, I texted that number the other day and it was fine then I could not send any messages due to the phone number format incorrectly pop up. I have a Google pixel and I tried sending messages to other contacts and have zero problem.
Thank you
10-04-2022 02:15 PM - edited 10-04-2022 02:15 PM
Hi there @GiuliaB1
Thanks for coming here.
Is the text to a number you have saved in your contacts?
Are you using the installed messaging app or a third party app?
on 10-04-2022 02:20 PM
Thank you, so I have followed the thread and tried to do everything that has been suggested. Deleted the number, checked that is a +44, cleared cache and storage, updated the app, switched on and off my Google pixel 4a and still nothing!
I have tried messagging others and no problems. The app is the one installed. I also messaged this contact previously and had no.problem
Thank you
on 10-04-2022 02:26 PM
on 10-04-2022 02:32 PM
I haven't tried, as I am out of the UK at the moment.
But still it would not explain what is going on!?
on 10-04-2022 02:53 PM
Also, I have noticed that all the other numbers I can text have these on the details - notification, app settings, oy send MMS and sms, block and report spam, verify encryption- but when I check the details of that number it doesn't show any at all
on 10-04-2022 02:56 PM
Thanks @GiuliaB1
Can you delete the contact again and try and text the number without this being saved, does this send?
Can you text the number from any other phone?
Leanne 🙂
on 10-04-2022 05:28 PM
I have some that 😕
on 11-04-2022 07:34 AM
on 11-04-2022 08:33 AM
I have. I have even tried to send the message to that number without saving it
