on 10-04-2022 01:25 PM
Did you get it sorted?I am having the same issue, I texted that number the other day and it was fine then I could not send any messages due to the phone number format incorrectly pop up. I have a Google pixel and I tried sending messages to other contacts and have zero problem.
Thank you
on 11-04-2022 09:24 AM
Hi @GiuliaB1,
Does your phone have an 'assisted dialling' feature in your call settings?
If it does, does turning it off resolve the issue?
on 11-04-2022 01:39 PM
Hi James. I have that feature and I tried as you said to turn it off a d try to send the message. It doesn't work, it still said number formatted incorrectly
I am really struggling with this!
on 11-04-2022 01:56 PM
The Pixel, and other phones, rely on Google Messaging syncing, so could be a conflict in Area or Region Code across the Phone and your Google Contacts Account.
A good place to start is by checking, editing or deleting and reinserting your Contact numbers here - https://contacts.google.com/
