Phone not working in Australia
Pwilliams10
Valued Contributor
Valued Contributor
Have been visoting Austrai for 20 years and pbones have always been fine.
Have paid for roam further but not phone access, or intdrnational calls nor any wecome to aus.
Dont have any access to complain
Wifi son in uk but ee would not do anything for him
44 REPLIES 44
Pwilliams10
Valued Contributor
Valued Contributor
At that time i could not make any headway with this , i was not familiar with its curious way of working.
Subsequently sorted by trial and error
send any reply to
[Mod edit: Please do not post your email address in this public forum. Thanks]
Christopher_G
OK, thanks @Pwilliams10
Those messages seem to confirm that the add-ons/inclusive extras are in place, but the ability to roam abroad needs to be activated on the SIM too. I know you've went abroad before, which usually means that the SIM is set up, but I recommend speaking with our Mobile Care team, just to make sure.
If you have access to your EE App, you may be able to start a live chat through the help section.
To add, in your first post you mentioned "Have paid for roam further but not phone access, or intdrnational calls nor any wecome to aus."
The roaming facility, which enables access to foreign networks, is free of charge and is crucial to having coverage outside the UK.
What you've paid for is a billing add-on, which reduces the cost of using that facility. Once the roaming facility is enabled, there's not usually any reason for it to be removed.
Yes that was a typo , for Not it should read have No phone access or internationsl calls, as the subsequent messaage.
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
My sim shows roaming and neteork as optus but mobile network state unknown.
Optus indicate restricted.
The Ee web chat eventually gets to saying call them  which i cannot do as phone restricted and ccannot make intrnationsl calls.
Nothing i put on 150 gets through just fails
WIthout a mobile network connection, then anything reliant on that - calls included - should be expected to fail.
Your symptoms are consistent with roaming not being active, or being set to EU-only. The only current mystery is exactly where your "SIM shows roaming"?
You may need to find another means to contact CS - a web-calling app such as Skype may be a solution, or obtaining access to another working phone.
I see i wad erong i did grt erlvom to zaud frkm ee
Welcome to Australia. You have a Go Further add on. This means you can call and text within Australia or back to the UK and use your data (up to 50GB fair usage) as you would in the UK. Click ee.co.uk/go-further for more details.
For the best network coverage your handset must automatically select a network. To do this, choose your phone from: http://ee.co.uk/help/phones-and-device next select 'Connectivity' then 'Selecting Network'
I see i was wrong i get s eelcom to sud from ee
To have received a welcome message demonstrates you had a mobile network connection and thus roaming is active.
If you are subsequently not able to connect to any local operator, may require a fault investigation raising by EE
So back to start  no apparrent way to contact ee for help when phone not working.
Chat bot told me to phone. Son in uk told he wasnt account holder. 8 hr time dif doesnt help
