07-05-2023 05:06 PM
Having problems on my EE mobile sim.
Calls from any number to my EE mobile number receive "busy" back.
I have tried the SIM in 3 different phones and the problem moves with the SIM.
Likewise, I have tried a different SIM in my EE phone and that works fine.
The problem is definitely with the SIM.
Any ideas
Andy.
07-05-2023 05:28 PM
Firstly check for any existing incoming call diverts that could be causing this - try following the phone's divert menu settings to cancel all diverts and then reset them by texting VM ON to 150
07-05-2023 05:42 PM
no diverts set.
I can turn VM on via 150, then I/C calls are diverted to my VM.
When I turn VM off via 150 VM is turned off, then I/C calls receive busy status.
This fault moves with the SIM, so it is a network problem.
07-05-2023 05:46 PM
What behaviour are you wanting, from incoming calls?
07-05-2023 05:49 PM
It would be nice if the phone rang.
07-05-2023 06:30 PM
Try setting and then cancelling firstly a conditional divert (divert if busy or unreachable) and if that fails, an unconditional divert.
Do so by the menus first, and if that fails using GSM # codes
08-05-2023 12:11 PM
I have tried setting diverts using GSM hash codes.
No joy, I am not allowed to divert calls.
