International Calls
Cels1
Hi!
I am currently abroad and need to make a call back to the UK. It says „This connection is barred for the requested destination“. Does anyone know how to resolve this?
@Cels1 : You're not making International Calls. Such are only made from UK. You are roaming.
Can you use data & send texts?
Thanks for your quick reply. I am on a contract and use this SIM everyday in the UK. I am abroad now and need to call someone in the UK with my UK number but that doesnt work. I can use the internet/whatsapp but I cant sent text on the messanger app/SMS it says „not delivered“. I also didnt turn on the „roaming“ before leaving the UK. When I try to send „roam“ to 150 the message cant be sent. Do you know if there is a solution other than contacting CS?
No, there's only 2 ways to have roaming enabled on your a/c:
  1. Text ROAMING to 150 while in UK, not from abroad. You didn't do this in UK & now you can't from abroad.
  2. Call CS to enable it for you. This remains your only avenue.
