‎24-07-2025 01:25 PM - last edited on ‎24-07-2025 02:11 PM by Peter_W
Hello, I have had a billing issue and my services has been cut off, I have tried calling 150 and 360 to resolve this but when I call the call just cuts off straight away, I have tried finding a live chat on the ee website but I cant find it, how do I contact ee to discuss my bill?
‎24-07-2025 08:10 PM
I’m unable to receive incoming calls, but mobile data works fine. iPhone16pro max. Tried everything. Mobile data works. I can make calls
‎24-07-2025 08:13 PM
It looks like it is not just affecting EE/BT, but also all the other major networks.
‎24-07-2025 08:24 PM
@Jurobond , there is a major outage, which EE are trying to sort out as a matter of urgency, and I have read, that all other major networks are having the same problem.
‎24-07-2025 08:32 PM
Hello @Odyone ,
Welcome to the community,
This has been extensively written about in other threads, there is a major outage with networks which EE are trying to rectify their end as a matter of urgency, it appears all networks seem to be affected by this outage.
‎24-07-2025 11:50 PM
@Schockwave wrote:It looks like it is not just affecting EE/BT, but also all the other major networks.
Alas not, this was the suggestion of clickbait news sites.
The EE issue with calling, affected users of other networks who tried to contact EE users.
‎25-07-2025 08:33 AM
A lack of coverage is not a symptoms of yesterday's calling issues, you may have a different problem..
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
‎25-07-2025 08:42 AM
I have been trying for days now to call EE or get onto their live chat is anyone else having issues??
‎25-07-2025 09:12 AM
Yes my mobile data is affected and calls are dropping but the service status page says "all fine"
It very definitely is NOT all fine
I don't even see the point of these service status webpages because they never are accurate
This is a well reported issue all across the internet and the EE website says no issue haha
Absolutely ridiculous
Will I be compensated for the 24 hours downtime?
‎25-07-2025 09:14 AM
It depends when you try. It is working at the moment but other customers will also be using the service.
‎25-07-2025 09:53 AM
