EE wifi mast problems
jockwav1
Spoke to someone on the 25-01-2023 about my BB speed dropping & very erattic.
He assured me it was a mast problem,all of a sudden.
Does anyone else have problems KA18 Auchinleck.
44 REPLIES 44
@jockwav1 : EE don't have WiFi masts. They are mobile network signal masts. WiFi is just the connection within your home for connecting your devices to your mobile router. It then thro' its SIM picks up the mobile signal broadcast by the EE masts.
To add, you can check for issues on EE's mobile network using the "check status" option on https://coverage.ee.co.uk/coverage/ee
jockwav1
Yes i have been doing so,i know something is not right with the signal coming into my wifi router.
jockwav1
I know EE don`t have masts,what i`m saying is my EE wifi router is what i use for my P.C. BB .
I have spoken to someone a few days ago who assures me he thinks they are working on a mast
that gives me my signal.I have been with EE for nearly 3 years,i know what signal i usually get
just all of a sudden it is all over the place.I will give them some time to get this sorted out before
i do anything else.
Leanne_T
Hi @jockwav1
Let us know how you get on once the mast issue is resolved in the area.
Thanks 🙂
Use the service status checker I linked to in my previous post.
There may be some subtleties getting lost in translation here, but "thinks they are working on a mast" sounds a tad vague to me.
Any known network issues should be reported on the tool. If nothing's showing, I would personally conclude there's no known basis to your problems.
jockwav1
Well it started on the 24th-25th Jan,i`m usually quite patient but this is so annoying.
I will give it a few weeks then look elsewhere if it is still the same,paying for bad BB not good.
jockwav1
Still no improvement in my fluctuating BB speed,it`s very unstable and they will increase their prices on 31st of March £5.50.😅
James_B
EE Community Manager
Hi @jockwav1,
Have you received any updates since reporting the problem via the Status Checker?
