Hotspot not working with ps portal
XydocX
My WiFi and friends hotspots (02 and giffgaff) work fine with the portal and we all have iPhones. On another forum somebody suggested downloading an ee APN IPV4 from GitHub which I did. It now lets me connect my hotspot but I now get an error when trying to connect to my ps5 with the portal (sorry, but something went wrong)
31 REPLIES 31
Leanne_T
Hi there @XydocX
Have you tried the tips in the How to troubleshoot issues on your PS Portal (UK) (playstation.com) page?
Hello,
Yes I have, I have also talked to them in their live customer service page and they explained that it has to do with something on your end since it works with my Wi-Fi and other providers hotspots.
They also said that yous may provide less than a 5ghz speed for hotspot although the portal needs a 5ghz speed to work. I am on a plan with unlimited data,texts and minutes.
Leanne_T
Thanks for the extra details @XydocX
Have you spoken to our tech guides to get this looked into?
I have not, I was going to try this first and if it did not work I was going to call.
Did you get any solution to this as I’m struggling with the same problem
I found out that the portal requires a 5ghz connection and ee provides a 2.5ghz data connection. I haven’t found a solution yet though. And don’t know if there is one, I haven’t called ee yet but I’m planning to.
Ali_A
Thanks for joining us on Community @Bradyoung
The 2.5Ghz and 5Ghz refer to the WIFI bands that is being used by the devices- it's the router, or in this case the mobile device, which dictates which band it's transmitting at.
If you are using a mobile device as a hotspot, you can go into your device Hotspot settings and manually set the band that you'd like to transmit.
For most androids it will be found in Settings > Connections > Mobile Hotspot and tethering
For iPhones it's usually set to 5Ghz as default, but you'll find it at settings > Personal Hotspot > Maximise Compatibility (set this to off)
Let me know if this works for you
Ali
Ali_A
@XydocX Can you pop into your mobile device hotspot settings and change it to 5Ghz?
Ali
It doesn’t work for me my device is iPhone 15 pro
